Frame swap help?
Old Jul 19, 2013 | 02:16 PM
Cooreman's Avatar
Cooreman
Default Frame swap help?
When considering a frame swap what all should I be looking for? I've got the wheelbase down and the width of the frame seems to be the same as well. Thinking about using a 90's circa ram I'm hoping to find a 93 for the full fuel injection but older could work too. Let me know guys I live playing on stuff like this but this will be by far the biggest project i will have done
Old Jul 19, 2013 | 08:29 PM
Brian in Tucson's Avatar
Brian in Tucson
You might reread your post and translate and elaborate. It don' make no sense and we don't unnerstan' whatcher wanting.
Mostly, if you want to do a frame swap, it should be for the same wheelbase and drive (2wd or 4wd are different.) A Ram frame wouldn't work as it was a full size truck and the Dakota wasn't.
Old Jul 19, 2013 | 08:37 PM
Cooreman's Avatar
Cooreman
I know it's not going to directly fit and I will have to modify things but I'm going for the solid axle and the easy lift so full size truck it is. I know it's been done with a Chevy frame before
Old Jul 19, 2013 | 09:04 PM
Cooreman's Avatar
Cooreman
And all I was wondering if there was some thing else to consider
Old Jul 19, 2013 | 10:17 PM
shadowthedakota's Avatar
shadowthedakota
mostly body mounts and the fuel filler and the bumpers
Old Jul 21, 2013 | 06:53 PM
Cooreman's Avatar
Cooreman
Fuel filler is a good one! Forgot about that thanks!
Old Jul 26, 2013 | 07:22 PM
moe7404's Avatar
moe7404
on ALL bolts on the bottom, exhaust bolts, and mostly break tubing fittings, use anti-seize compound. after 70,000 miles you will e glade you did. all so do not use plated bolts on the exhaust system. the plating will come off and jam the threads. and DO use the same size bolts that the factory did on the exhaust bolts. a smaller bolt WILL come loose.
Old Jul 28, 2013 | 09:47 PM
Cooreman's Avatar
Cooreman
Thanks I had no idea
