Hallowed out cat?
Old Jul 26, 2013 | 12:50 AM
Cooreman's Avatar
Cooreman
Default Hallowed out cat?
So I've got my truck cut just after the cat (in the middle of switching exhaust systems) I'm just wondering if I should hallow it out or not. (I don't have emissions up here I'd just keep the cat case for traveling so it looks like it would pass) so my question is leave it till it plugs or cut it out now? She's only got 163000 kms that's 10100 miles for you Americans ahaha
Old Jul 26, 2013 | 12:54 AM
Brian in Tucson's Avatar
Brian in Tucson
I was following a Gen2 Corvair the other day. You could smell the unburned hydrocarbons a half mile (a bit less than a km for Canadians) away.
There's vir-tually (why does the censor cut vir-tual?) no performance or fuel mileage penalty for leaving the emissions stuff on and functioning. And your rig will run cleaner. I guess I'd just leave it alone and be a good steward of the local air quality.
Old Jul 26, 2013 | 05:19 PM
BKCowGod's Avatar
BKCowGod
A good, modern cat will not kill your MPG or your performance.
Old Jul 26, 2013 | 07:48 PM
Brian in Tucson
I think that's what I said. . .
Old Jul 26, 2013 | 09:11 PM
BKCowGod's Avatar
BKCowGod
That's what I get for opening the thread and then walking away before I respond...
Old Jul 26, 2013 | 10:13 PM
Cooreman's Avatar
Cooreman
I ended up leaving it on for now until she clogs thanks!
Old Jul 27, 2013 | 09:48 AM
primem's Avatar
primem
if you remove the cat you will get a p0420 dtc
Old Jul 27, 2013 | 11:31 AM
Cooreman's Avatar
Cooreman
What is that
Old Jul 27, 2013 | 01:01 PM
BKCowGod's Avatar
BKCowGod
It's a computer error code, but if I recall you're OBD1 and that's an OBD2 code.
Old Jul 27, 2013 | 05:40 PM
Cooreman's Avatar
Cooreman
Yes obd1 I only have one o2 censor before the cat so it wouldn't change how it runs it would just allow more **** to blow our instead of catching it. Also helps dampen my exhaust so it doesn't sound like a res rocket
