92 dakota problem
Old Sep 16, 2013 | 07:34 PM
J-Hub's Avatar
J-Hub
Question 92 dakota problem
Hello, I recently acquired a 1992 dakota 3.9l V6 with 227k miles on it. The truck will lose oil pressure upon warming up and will want to stall under light acceleration coming from a stop. When it loses oil pressure theres no ticking or abnormal sounds coming from the engine which leads me to believe it is the sending unit. Any and all information will be appreciated. Thank you for taking the time to read and or reply.
Old Sep 17, 2013 | 10:51 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 1st generation Dakota sub-forum.
Old Sep 17, 2013 | 12:20 PM
Brian in Tucson's Avatar
Brian in Tucson
Oil pressure senders are cheap to replace and not difficult.
There are those who would suggest, tho, that the oil pressure sender & gauge are really not very accurate and that you should maybe install a mechanical gauge for a bit more accuracy. I dunno.
Old Sep 17, 2013 | 10:27 PM
J-Hub's Avatar
J-Hub
Alright. Ill look into a mechanical gauge. Do you happen to have any idea how much they cost?
Old Sep 17, 2013 | 11:05 PM
vhinze's Avatar
vhinze
My sender suddenly got erratic around 200k, before that, it served me well.
I splurged ten-twelve bucks and got a new one. I'll be happy if I live long enough to see it go south.
Old Sep 17, 2013 | 11:06 PM
shadowthedakota's Avatar
shadowthedakota
i paid about $20 for my mechanical gauge at the autostore. they can be had cheaper at swap meets or farm stores. i dont use mechanical gauges anymore. i found a guy at the swap meets who sells electric gauges at $2 a pop.
Old Sep 19, 2013 | 10:05 AM
J-Hub's Avatar
J-Hub
How difficult would a mechanical gauge be to install?
Old Sep 19, 2013 | 02:55 PM
shadowthedakota
its easy once you get the old sending unit out. the hardest part is it being on the back of the motor
Old Sep 19, 2013 | 09:17 PM
J-Hub's Avatar
J-Hub
Awesome. I'll look into it. Thank you for your input.
