Cooler Line
Old Sep 21, 2013 | 12:31 PM
dobaroy's Avatar
dobaroy
Default Cooler Line
93 Dak, 5.2, 4x4, just a mud truck. What can we do to keep the cooler line hose on the rad fitting. It just seems to keep popping off. Any ideas would be welcome. Thanks
Old Sep 21, 2013 | 08:49 PM
moe7404's Avatar
moe7404
mod the rad to use a steel line all the way. but the steel tubing will need to do two or 3 coils from the trany to the rad as a flex joint. AND use only steel tubing, do NOT EVER use copper. the factory uses steel tubing for a reason. a few zip ties at the right places should help.
Old Sep 22, 2013 | 07:42 AM
dobaroy's Avatar
dobaroy
Thanks Moe, gonna try that.
Old Sep 22, 2013 | 11:28 AM
shadowthedakota's Avatar
shadowthedakota
Did you try replacimg the hose clamp? I had that problem with my 91 and I resolved it with 2 hose clamps
Old Sep 22, 2013 | 08:07 PM
Tom A's Avatar
Tom A
Section Moderator
If you have a flaring tool, you can flare it a little bit.
Old Sep 23, 2013 | 05:54 PM
moe7404's Avatar
moe7404
NEW idea. put a longer hose on. may have to cut the tube. dont fore get the zip ties. the other ideas are good to.
