Control arms do not pivot
Old Sep 29, 2013 | 06:09 PM
Cooreman's Avatar
Cooreman
Default Control arms do not pivot
As you guys know I've been lifting my truck and the control arms don't seem to pivot when I jack it up it just lifts the truck. Any ideas that could cause this?
Old Sep 29, 2013 | 07:48 PM
cd36's Avatar
cd36
Sounds like your torsion bars are cranked so much they are resting on the bump stop so when you jack up the frame there is no suspension travel, just lifts instantly. Take some pictures of your suspension.
Old Sep 29, 2013 | 08:22 PM
Cooreman's Avatar
Cooreman
The problem is with the torsion bar. The upper control arm is slammed on that bump stop and the torsion bolt is just enough in to hold every thing in place. God damn why.
Correction; when the bolt is hardly in my control arms pivot but any thing after that an the movement becomes limited as the bolt turns up.. It hardly has to be turned up
Old Sep 29, 2013 | 08:48 PM
cd36's Avatar
cd36
Take some pictures. I know you were installing a trailmaster kit and I am unfamiliar with them. Are you using the standard keys or lift keys? With the torsion bar backed right off does it sit the other bump stop or does it get hung up?
Old Sep 30, 2013 | 12:46 AM
Cooreman's Avatar
Cooreman
I don't know how to post photos on here I'm on my phone. And same keys it has a drop bracket. When I put my tires on an put the weight onto the bars when tightening then the worked correctly.. I haven't got a clue why
