The dreaded solder joint!!! Please send me a link
Subscribe
Oct 24, 2013 | 07:11 PM
All,
Trying to help a follow Dakota owner out. Sounds like he has the dreaded solder joint issue. Can someone send me the link on how to fix this? I thought it was under FAQ, but I couldn't find it. Please advise and thank you.
Reply 0
Oct 24, 2013 | 09:31 PM
dang i thought i had a pic for this.
if you remove the tape right at the relay box you should be able to find it. i fixed mine with a wire cap and some tape and its been fine ever since.
it does help to unbolt the relay box, flip it over, and remove the bottom piece exposing thewires
Reply 0
Oct 25, 2013 | 04:46 PM
if the a solder joint is on steel, reg solder will NOT hold. you need silver solder. a good weld supplier should have it.
Reply 0
Oct 26, 2013 | 10:13 AM
The "Splice" is three red/white wires to one red/white wire. There's no need for silver solder.
Here, I hope, is a link:
https://dodgeforum.com/forum/1st-gen...ml#post1678925
Reply 0
Subscribe
