87 Dak with High Idle at StartUp......
Old Nov 1, 2013 | 09:10 AM
Ihrugby's Avatar
Ihrugby
Default 87 Dak with High Idle at StartUp......
Hey Guys.........Got an early 87 model with no frills and whistles but it runs like a Banchee, after a couple minutes of warming up and have to hit the pedal a few times, untill it releases and sets at 750 perfect idle. Should this take this long to warmup and run with a racing idle around 1250 rpms? Everything is orginal, including the 2-barrel Carb. Rebuilt the whole top end after 225k and I have 374k on it now. I think I need new ball joints, but you got to be carefull when closing the door, sounds like a tin can, and got old retro whitewall 15" tires on it.........I probably should post a few pics in the other section of the forum. Used to have my own version of this truck but it was a later 87 Model and had all the extras they gave back then........TIA
Old Nov 1, 2013 | 01:22 PM
Ihrugby's Avatar
Ihrugby
Default 87 Dakota Racing Idle till Warmed Up
Sorry Guys forgot to give all info it's a 3.9 Liter engine with all original stock parts........and components.....
Old Nov 1, 2013 | 06:25 PM
onemore94dak's Avatar
onemore94dak
Take the air cleaner off and give the carb a good going over with carb cleaner. If that don;t work try doing a carb kit. Oh yea look for vacuum leaks.
