Special tools for timing belt & rear oil seal
Old Nov 2, 2013 | 04:07 PM
dspenc79's Avatar
dspenc79
New Member
Default Special tools for timing belt & rear oil seal
I have a 1988 Dakota. I need to replace the timing belt and rear crankshaft oil seal but cannot rent the special tools for the job. It sounds like something I could do on my own if I had the tools or knew if something else would work in their place. Anyone have a suggestion ?
Old Nov 2, 2013 | 09:41 PM
Cooreman's Avatar
Cooreman
Can't rent it buy it
Old Nov 3, 2013 | 12:13 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
I imagine you are talking about the 2.5 engine. You need to provide more information when asking a question. The only special tool you need is the timing belt tensioner tool: http://www.thedodgegarage.com/tools.html
The reason you need this is to get the proper tension on the belt. Too much tension and the belt tries to walk off the gears. Not enough tension and the belt will walk inward off the gears or jump a couple of teeth. You can try different tensions by adjusting the belt and then starting it to see where it rides. If it walks away from the engine it's too tight, if it walks towards the engine it's too loose. It should ride right in the middle.
As far as doing the rear main seal, I just pop it out with a screw driver and tap the new one in with a hammer and punch. Be careful not to tap it in too far. There is not a stop for the seal so you can tap it in too far. Make note of where the old one sits. It should be flush with the rear main seal retainer.
