EGR code
Old Nov 10, 2013 | 11:36 AM
ednev's Avatar
ednev
Default EGR code
Ok i have switch out 4 different EGR and solenoids and cleared the computer each time and i still get bad EGR codes. Any ideas?
Old Nov 10, 2013 | 02:55 PM
RockGuardedDak's Avatar
RockGuardedDak
Clogged egr port maybe? Or broken wire on the connector?
I wouldn't worry about it too much tho, the egr has been bad on my '93 for 5 years or more and I've never had any run ability issues with it
Old Nov 10, 2013 | 06:20 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Are you getting vacuum to the solenoid? Is the passageway in the intake or the tube going from the exhaust manifold to the EGR valve plugged?
Old Nov 11, 2013 | 11:16 PM
ednev's Avatar
ednev
Ok it has vacum from the manifold line and the bottom line thats
on the egr base is blowing warm air so im going to swap power connectors and see what happens.
Old Nov 12, 2013 | 12:28 AM
AZ 360 Dakota
What about the passageway in the intake? Does it flow? I've seen those pretty junked up.
Old Nov 14, 2013 | 12:07 AM
ednev's Avatar
ednev
Ok well I pulled it off its not plugged and i put a test light on the power connector and that has power so hmm idk.
Old Nov 14, 2013 | 01:46 PM
AZ 360 Dakota
Pulled what off that's not plugged?
You're going to have power at the EGR solenoid plug. The computer switches the ground to command it on/off.
Old Nov 22, 2013 | 12:35 PM
onemore94dak's Avatar
onemore94dak
Try disconnecting the neg battery cable for 5-10 minutes. That should clear all codes. Then reconnect and check the codes without starting the motor to be sure they cleared and then take it for a drive 5+ miles should be enough for the PCM to adjust to the new EGR. Re-check to see if it has reappeared.
I don't know how diagnose further except to say install a new EGR and clean up the mating surface on the motor. I had an EGR code, replaced it and it went away as soon as I drove it and re-checked the codes. 94 Dakota 2wd
Old Nov 25, 2013 | 02:03 PM
ednev's Avatar
ednev
I have tried everything I think my next step im going to replace the connector it is pretty stiff anyways.
Old Nov 25, 2013 | 02:35 PM
AZ 360 Dakota
Did you check the passageway for EGR flow in the intake manifold?
