Front wheels jump
Old Dec 3, 2013 | 03:54 PM
1hidakota's Avatar
1hidakota
Default Front wheels jump
Hi there. So recently my transfer case started jumping out of gear and now when I make a tight turn the front tires start jumping and chirping. Any ideas on what could be wrong before I start shoveling out money. Thank you it's a 1995 dakota 3.9 4x4
Old Dec 3, 2013 | 09:48 PM
Tom A's Avatar
Tom A
Section Moderator
Sounds like it's in 4WD all the time. I assume you have the lever in the 2WD position?
Old Dec 4, 2013 | 12:35 AM
Cooreman's Avatar
Cooreman
Building off of what Tom said if it jumps out of gear maybe it jumps into gear as well?
Old Dec 4, 2013 | 07:29 AM
1hidakota's Avatar
1hidakota
Yes lever is in 2wd I tried adjusting but same problem
Old Dec 4, 2013 | 10:27 AM
shadowthedakota's Avatar
shadowthedakota
your axle might not be disengaging. I had the same problem with my dakota.
Old Dec 4, 2013 | 10:59 AM
shop.squadworks's Avatar
shop.squadworks
Sounds familiar. Mine is also a 95, but with the 5.2. My t-case works, but feels a little dicey on its detents.
