Brake issue???
Old Dec 15, 2013 | 09:08 PM
Reesey's Avatar
Reesey
Default Brake issue???
I am wondering why my rear brakes only work in four wheel drive. Is this normal or is something amiss? '91 dakota sport 4x4 with 3.9
Old Dec 15, 2013 | 09:17 PM
92DakotaClub's Avatar
92DakotaClub
rear drum are a self adjusting... usually the adjuster fails or seizes up or just don't work. usually tho it only works in reverse I heard.... idk on that tho some say Ebrake play adjusts....
in 4x4 ur front will have power to stop entire...
Old Dec 15, 2013 | 09:30 PM
Reesey's Avatar
Reesey
Here is a little more info. I live in N.Y. And when in two wheel, i slide all over in the snow(even at 5 mph). In four wheel i stop on a dime. Just wondering why that is.
Old Dec 15, 2013 | 09:53 PM
92DakotaClub
front lock and rear still power on... were as in 4x4 it will slow entire drive train from front brakes... I know I have same issue last winter...
Old Dec 15, 2013 | 10:04 PM
Reesey's Avatar
Reesey
Thanks a lot. I have a hissing when i brake also but I know thats the booster. I'll be replacing that. Four wheel drive in the snow it is.
One last thing. My truck when warmed up idles at about 250 rpm. Is that normal? When its a cold start it idles at around 900-1000, then drops when warm.
Old Dec 15, 2013 | 10:28 PM
92DakotaClub
yours actually warms up? I removed the fan and my guage still dosent move much more LOL but no that's not normal idle is usually 700 or so when warm... AIC motor might be culprit there.... or might be the vacuum leak causing that
Old Dec 15, 2013 | 10:55 PM
Reesey's Avatar
Reesey
Had that problem when i bought the truck. Found it was the thermostat was bad and when they go bad they stay open. Replaced the original 190 degree thermostat with a 160.
Old Dec 16, 2013 | 08:47 AM
Alfons's Avatar
Alfons
Try adding some weight over the rear axle (3 or 4 bags of sand will work). The Dakota is really light and most of the weight is in the front so the back doesn't hold all that much when you hit the brakes and will slide out.
Old Dec 17, 2013 | 10:26 PM
bran1har's Avatar
bran1har
the rears are self adjusting, but only if you use the parking brake frequently so just engage/ disengage you parking brake many time repeatedly and they will adjust themselves. or the pads are shot/ drums are glazed. rear brakes on dakotas are ****.
Old Dec 17, 2013 | 10:35 PM
92DakotaClub
yea if the adjuster didn't seize up like they usually do or the adjuster cable snap :O or lever bend.. in a perfect world yes they self adjust but remember its a Chrysler product....
I usually jack up the rear of the truck block front wheels put in neutral .. pop out the little rubber grommet and adjust mine every month till I feel it grab when turning tire . takes a few minutes with a flat screw driver
