no fuel pressure
Old Dec 27, 2013 | 08:21 PM
  #21
Alfons's Avatar
Alfons
Originally Posted by spoon6832
pump had a bad contact,fixed but still wont run. pressure on fuel rail on key hits 40 psi but drops to 31 psi and holds. during cranking is 39 psi steady
That's good pressure (39 t0 40 psi), and if it holds at 31 with the key OFF for about a half hour, that's also good. I'd say offhand that the regulator is also working since the pressure holds and also keeps steady at 39 while cranking (the pump can go much higher than that).
Have you the diagnostic codes recently? Do you have a spark?
Old Jan 14, 2014 | 10:51 PM
  #22
spoon6832's Avatar
spoon6832
I had to replace echo ring ,truck starts every time now,but stalls right away
Old Jan 17, 2014 | 03:46 PM
  #23
Alfons's Avatar
Alfons
Maybe I don't use the same terminology, what's an echo ring?
Also, are there any codes stored now?
Old Jan 20, 2014 | 12:21 AM
  #24
spoon6832's Avatar
spoon6832
A piece in distributor .no codes
