Spitting and sputtering plus code 22
I have a 92 dodge dakota 3.9 v6 which recently had overheating issues. The issue has been fixed.
I put a tune up on it:
plugs
wires
cap
rotor
fuel filter
oil change
pcv
aic
brakes all around
air filter
Now when I get up to highway speed and get on the gas it will spit and sputter slightly. I checked the flash codes and got 12, 22, and as always 55(end codes).
I believe that the code 22 is due to me unhooking the wires when removing the thermostat without knowing it and starting the truck. Idled funny before I realized what happened. Idled real high, real low, real high, etc... Plugged it back in and no problems. Just havent reset the codes yet.
12 is battery has been unhooked within the last 50 starts.
What could be causing the spitting and sputtering??? Could it be lines arent tight enough around the fuel filter? Plug wires got mixed up? Rotor not positioned right?
Thanks in advance.
plugs
wires
cap
rotor
fuel filter
oil change
pcv
aic
brakes all around
air filter
Thanks in advance.
Just replaced the fuel filter. It is still happening and I can hear an audible crackle from one of the plugs(cant narrow down which one), so I am going to remove them all and re-gap them. Add more dielectric grease or whatever and re align the wires on the dizzy.
Okay, so I awoke this morning and went out to start the truck. I found that I am getting intermittent exhaust(its cold here so I can see it). It will be real low, then normal, then none and the entire truck shakes. Could it be from a clogged cat?
Went thru the entire ignition again and the rotor has about 1/4 inch of play in it. Printed out plug to cap diagram and followed exactly.
It idles rough, and on take off from stop sign and such. When it is parked and I get on the gas a couple times revving the engine there is no problem except when rpms come down. I get a little backfire then. I am at a loss here. Thought maybe clogged cat or muffler?? When at idle it seems quieter but I get small bursts or what sounds like a small rev.
On an OBD1 engine, the distributor shouldn't move externally. Once it's installed properly, it should be bolted down solid - there should be a bolt and clamp holding it to the block. Any motion will change the timing and would make it run poorly.
