TrailMaster Shocks and lift kit
Old Jan 31, 2014 | 07:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Talking TrailMaster Shocks and lift kit
Here are a few PDF's I found on a long lost PC.
Lift kit install
https://drive.google.com/file/d/0BzA...it?usp=sharing
Monroe Shock Sensa Trac (Coil over spring shocks/Towing shocks)
Shock dimensions
Shock Mounting
Old Feb 1, 2014 | 10:41 AM
92DakotaClub's Avatar
92DakotaClub
You need permission
Want in? Ask the owner for access, or switch to an account with permission. Learn more
msg when trying to access last link.. lift install
Old Feb 1, 2014 | 11:58 AM
Cooreman's Avatar
Cooreman
Well I appear to have every thing but what looks to be that skid plate infront of the new cross member dang an incomplete lift ahahaha
Old Feb 1, 2014 | 12:36 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by 92DakotaClub
You need permission
I set it up only those who have the link can access it, even without a google account.
If it is just a skid plate you need, build a custom one, that will be easy.
Old Feb 11, 2014 | 05:36 PM
Cooreman's Avatar
Cooreman
I just ended up remodelling the old skid plates aha
Old Apr 27, 2014 | 09:06 PM
chopper240's Avatar
chopper240
Default 4" suspension lift
Do you have experience with the 4" lift on '92 Dakota. I purchased a '92 with this lift installed and at the time it had 33" tires. The inside 1/3 of tread was bald. I put 31" tires on and now its eating the inside tread again. I took it to shop but they would not align, said too many wore out parts. I replaced upper/lower ball joints and pitman arm. I havent taken back in for alignment yet. I noticed the upper a-arm seems to be adjusted as far as they will go but the alignment is still off.
Old Apr 27, 2014 | 09:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I don't have experience with this kit, but my guess is if it is maxed out on the adjustment there probably is something that is bent causing the mis-adjustment. Replace all the necessary parts, then take it back to the shop for an alignment. If needed take it to a 4wd specialty shop or offroad shop they usually will be used to adjusting lifted vehicles.
Old Apr 27, 2014 | 10:34 PM
92DakotaClub
its also possible the torsion keys are cranked to far pulling top arm inward causing inward tilt of upper tire causing inside edge wear..
