how to reset check engine light on 1991 3.9L??
Old Feb 6, 2014 | 10:12 PM
Busseyte's Avatar
Busseyte
Question how to reset check engine light on 1991 3.9L??
I recently got a code for a bad hall effect/pickup sensor after the truck left me stranded. Ive replaced the sensor and while I was trouble shooting for another problem I may have had I removed the battery leads. The truck is running now after all repairs but when I do the engine code check procedure (On and off ignition 3 times) its still showing me that the hall effect sensor is a problem and that the battery has recently been disconnected. Is there a way to reset the system?? Thanks in advance!
Old Feb 7, 2014 | 12:25 AM
shadowthedakota's Avatar
shadowthedakota
Disconnect the battery and hold the brake pedal for 15 seconds, then drive for 20mins without shutting the truck off and that should reset the pcm.
Old Feb 7, 2014 | 10:11 AM
Busseyte's Avatar
Busseyte
Thank you! Ill give it a try this weekend.
Old Feb 10, 2014 | 07:44 AM
Busseyte's Avatar
Busseyte
It worked great thanks!!
