Heavy duty flasher question
Old Feb 19, 2014 | 03:49 PM
1993dd's Avatar
1993dd
Default Heavy duty flasher question
In order to pull my trailer without my blinkers blinking super fast, I know that I need a Heavy duty flasher to support the load. However, my hazard lights blink at the normal speed. A new flasher is $20! (I'm cheap). What I was thinking was: Can I just switch the 2 flashers? I definitely will use the blinkers more than the hazards. Are they interchangeable? Thanks!
Old Feb 19, 2014 | 05:50 PM
92DakotaClub's Avatar
92DakotaClub
a dodge without 4 way flashers? ARE YOU MAD BRO? lol
take it out and try not like its a timely adventure
Old Feb 19, 2014 | 06:02 PM
1993dd's Avatar
1993dd
Well I've never had to use the flashers before. Its never stranded me.
Old Feb 20, 2014 | 05:08 PM
Alfons's Avatar
Alfons
The normal (cheap) flasher unit is made up of little more than a bi-metalic strip that heats up under load (the normal flash or turn signal load) to break the contact and then cools quickly and makes contact - there are no other electronics/mechanics in this flasher to deal with a load such as added trailer lights would give & this is why it flashes very fast (it heats up really fast from the added load). This added load will cause your normal flasher unit to fail quickly as well, the heavy duty unit will have a completely different switching system (you can see all the components in the clear case units) as well as built-in arc protection for the switch contacts (the contacts on the cheap ones will fry real fast with the added load - they're OK as an emergency spare). By the time you change your normal flasher a few times by being "frugal", the heavy duty unit won't seem so expensive.
Old Feb 20, 2014 | 10:16 PM
RalphP's Avatar
RalphP
Cheap, but heavy duty, can be had by actually shopping around some:
http://www.rockauto.com/catalog/rafr...parttype=10139
OTOH, I picked up a Tridon EL12 for about $12.99 at Auto Zone in town. Cheaper after shipping was figured in, plus by going through the Fuel Rewards Network website, I get credit for it against my gas bill (not much, $50 purchased yields 5 cents/gallon off ... but eh.)
RwP
Old Feb 21, 2014 | 10:06 AM
Alfons's Avatar
Alfons
RwP
With that link, you can see that you don't need to replace too many cheap ones to equivalence the price of one HD unit, plus, you end up with FULL and DEPENDABLE functionality with the better unit. I have never seen one of those HD units fail.
