91 5.2L Magnum AC delete
Old Mar 10, 2014 | 07:53 PM
scottyspades's Avatar
scottyspades
Default 91 5.2L Magnum AC delete
My ac has a blown o-ring and im planning to remove it. Can i cheat and buy a belt for a non AC equipped 5.2 or do i have to fabricate/buy an idler pully/AC delete kit?
Old Mar 11, 2014 | 08:34 PM
Hahns5.2's Avatar
Hahns5.2
Magnum in a 91?
If it is a Magnum, the AC bracket places the idler in a slightly different spot than the non-AC bracket, so a non-AC belt is a bit too short when used with the AC bracket. The non-AC belt is 88.5" and you need 89.5"-90.5". Simply ask for a belt for a 2010 Tacoma with a 2.7L with AC. This will get you a 7 rib 90" belt.
Old Mar 11, 2014 | 10:56 PM
moe7404's Avatar
moe7404
i think i have seen brackets that replace the A/C, with a pulley that just goes along roe the ride. and use the A/C belt. i think i saw it at summit.
Old Mar 12, 2014 | 12:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Are you sure it is a Magnum? Magnums first came out in Dakotas in 1992. 1991 would have the older LA engine. For the magnum there is an A/C Compressor Bypass Pulley you can buy. http://www.autozone.com/autozone/par...38297_0_15373_
I'm not to sure on the LA engines, check www.autozone.com or www.napaonline.com or www.google.com
Old Mar 12, 2014 | 08:36 AM
scottyspades
Its definitely a magnum. Fender badging, magnum snorkel air cleaner, overwhelming desire to roast rubber whenever i pull out above idle lol. Idk if one of the 2 former owners did a motor swap, or if it was a special order, but the motor definitely looks like it belongs between the fenders
Old Mar 12, 2014 | 10:06 AM
92DakotaClub's Avatar
92DakotaClub
if all you did is blow an o-ring honestly no reason to replace... my compressor has a blown inner bearing... just dont use it.. AKA unplug it, the clutch wont engage , since my clutch bearing is perfect its all i did
Old Mar 12, 2014 | 07:22 PM
jockjock's Avatar
jockjock
The bypass pulley is actually available for magnums all the way to 96, they sell two varients at the NAPA down the street. As far as deleting it goes, the HP increase is not worth it if you live somewhere with lots of rain or snow.
Old Nov 15, 2020 | 04:51 PM
Markpollard's Avatar
Markpollard
With no modification besides removing a/c compressor and hounestly i dont think you even have to do that
Old Nov 15, 2020 | 08:22 PM
RalphP's Avatar
RalphP
I hope in the six years since 2014 the original poster has handled it ...
RwP
Old Nov 15, 2020 | 08:33 PM
Markpollard
RwP
haha lol I realised that after I posted..
could be help to others doing same thing.
