Removing pins from gauge cluster connectors?
Old Jun 21, 2014 | 01:31 PM
greenweenie's Avatar
greenweenie
Default Removing pins from gauge cluster connectors?
The previous owner of this 94 Dakota I've been working on cut a wire off flush at one of the connectors that plugs into the back of the cluster. I have a tool for removing pins from factory connectors but I can't seem to get any of the fittings to get the pin to pop out so i can solder it.
Has anyone had any luck removing the pin, and if so which tool is needed?
Thanks
Old Jun 29, 2014 | 11:20 AM
T.C.'s Avatar
T.C.
Well I was able to just use a simple pair of vice grips and wiggled them out, though I wouldn't recommend it. Why are you trying to remove the pins anyways?
Old Jun 29, 2014 | 12:04 PM
archemedes74's Avatar
archemedes74
I always use a dental pick with no problems
Old Jun 29, 2014 | 09:37 PM
onemore94dak's Avatar
onemore94dak
I just found a TSB that describes removing "terminal" connects which is what they seem to be calling the ends of the wires. http://dodgeram.info/tsb/1994/08-33-94.htm
In it they describe a wedge in the socket with the terminal holding it in, and say not to break it as you remove it. I suspect you have to locate the wedge holding the terminal end of that wire in and don't bgreak it and save it if you need to put a wire back in there.
