fuel pump not working
As the title says my fuel pump quit working. I was having these issues before so I put a brand new pump in and it worked for a while then one night I went to the station and stuck 10gals in the tank and I nearly got a ticket for disorderly conduct from all the curse words. Well any way I got the truck towed home and I ran the pump off the battery and I got nothing so I switched it out with a used but known working pump and still got nothing. I can run the pump off my 12v inverter and they both work...wierd
Any thoughts?
Any thoughts?
There is a fuel pump relay under the hood.Switch it out with lets say the one for the a/c and try it then.If it works just get another relay for it..I had this same issue as yourself.First time it WAS the pump second it was the relay. 1 1/2 later and still no problems. Also,if the relay is not the problem you may have a bad ground somewhere.
To add to 1stG92 - time to drag out the wiring diagram and start checking.
Swap the relay if possible with another one (all of mine are unique on the 1988, but the ASD is a standard Bosch pinout, so my stock of Bosch relays works to test there!).
Then it's time to volt / ohm the wiring back in case the wiring quit.
Oh, and be sure to measure voltage along the way - one of the ways the ignition switch can fail on my (not the same vehicle!) Cougar is to drop power to fuel and injectors by screwing up power to the ECU ... could be as simple as a bad switch.
RwP
RwP
I know the splice is good because that's how I got the truck for cheap. I opened up the harness because I had a wire burn up last year and all of them were good. I don't recall hearing the relay so I'll check that
Update. I put a new pump in and I had no power to it (it was a working spare) all the relays work. I have power at 30 on the fuel pump relay and asd relay and power at both 30 and 86 on both relays. But I also have low power at 85 on the fuel pump relay. Is this normal?
Trending Topics
I'd say it is your wiring as that is a known problem with dakota gas gauges/fuel pump.
Here's a couple of sites I found I couldn't find the Edmonds article for my dakota that explained what the wires were doing. Its got something to do with the wires breaking or the connection inside the connector at the tank failing.
http://www.justanswer.com/dodge/4ufd...backwards.html
https://answers.yahoo.com/question/i...=1006050619001
Look what I just found!
http://dodgeram.info/tsb/1994/08-33-94.htm
Wish I had that when I changed my pump now I have to do it again.
