Fan hitting tranny cooler line
Old Jun 28, 2014 | 06:36 PM
Cooreman's Avatar
Cooreman
Default Fan hitting tranny cooler line
Well I've completed my body lift near a month ago and I'm apparently still running into problems. Most people have it cut the rad hose which is an easy fix, mine cleared the hose but under the right circumstances ect. Leaving my garage. The fan hits the hose clamp on the tranny cooler line. It's also the small side of the clamp not the large I've already rotated it. Has any body else ran into this? My options I came up with are 1 an electric fan ( I've tried it before turned out to be a pooched motor haven't found one with the right cfm since. I have all the wiring it's the kind with the probe into the rad sort of deal. 2 attempting to bend the connector at the rad down 3 eliminate tranny cooler from rad and run two Infront.
