Brakes
Old Oct 20, 2005 | 09:23 AM
bigowe's Avatar
bigowe
Default Brakes
O.K. guys i just bought a 88 dakota and it has a brake line leak just behind the drivers door there is a junction block i guess you would call it, it actually looks like a little master cylinder. it has a return spring and a lever and a plunger, does anybody know what this is? and where can i get one. Also where is the most reasonable place to get front wheel hub and bearing assembly.
Old Nov 6, 2005 | 02:35 AM
Chump's Avatar
Chump
Default RE: Brakes
Try autozone for the bearing...I'm not sure what the other part is...do you have a pic you can post?
Old Nov 6, 2005 | 09:36 AM
bigowe's Avatar
bigowe
Default RE: Brakes
I figured it out the thing is called a ride height sensing proportioning valve it adjusts rear brake pressure on how your truck is loaded. well it is gone now plugged the line off and ran a new brake line to the rear and it"s gone. Bigowe
