1995 Dodge Dakota 2wd Upper Ball Joint? Help!
Old Aug 29, 2014 | 06:55 PM
Master X964's Avatar
Master X964
Default 1995 Dodge Dakota 2wd Upper Ball Joint? Help!
So my manual says i need this [C-3564-A Ball Joint Separator](http://www.etoolcart.com/balljointse...-c-3564-a.aspx What is this tool, i thought they just threaded in? I already have the socket, anyone have a better tuturial (I have the Factory Service Manual and the Chilton's Manual), [Here](https://i.imgur.com/4QpMwon.png) are the instructions from the Factory Service Manual, saying i need that tool, the C-3561 is the [Ball Joint Socket](
Alltrade 648749 Kit 32 Specialty Ball Joint Socket Tool Set - Hand Tool Sets - Amazon.com Alltrade 648749 Kit 32 Specialty Ball Joint Socket Tool Set - Hand Tool Sets - Amazon.com
) that I've already bought. What am I missing/not comprehending, honestly, I'm so lost...
Edit: Fig. 7: https://i.imgur.com/KvnbZMm.png
Old Aug 29, 2014 | 09:12 PM
93 ragtop's Avatar
93 ragtop
I used a pickle fork to separate mine. One something like this. http://www.ebay.com/itm/New-Tie-Rod-Pickle-Fork-/380984199076?pt=Motors_Car_Truck_Parts_Accessories&hash=item58b46d87a4&vxp=mtr
To replace the ball joint, you remove the bottom nut off of the ball joint. Take the pickle fork, and drive it in between the knuckle and the control arm.
Then you screw the ball joint out. FWIW I found a used snap on socket on ebay for 20 dollars, and in my case I really needed the 3/4 breaker bar with a pipe on the end to separate it.
Also, you do know you have to take the spring loose. Not sure how you do this on a 2wd. The 4wd has a torsion bar so its different. Also I removed the brakes and rotors. Not sure if you have to, but it makes access easier.
Old Aug 29, 2014 | 10:17 PM
Master X964
Ohhhh, okay thank you very much, i feel stupid now lol, can't understand a stupid fsm, oh well that's why there's forums right :P
So wait.... I have to remove the spring? It says i only need to put a support/jack stand under the control arm, I know for the lowers i have to take the spring out.
Old Aug 30, 2014 | 08:12 AM
93 ragtop's Avatar
93 ragtop
Well mine is 4wd and its different so Im not for sure. It may be you just have to support the lower control arm to keep it from dropping or springing down when you separate the ball joint from the knuckle. Hopefully someone with experience with the 2wd will step in.
Old Aug 30, 2014 | 08:52 PM
Master X964
Thank you for all your help, got them both in today, after going to the store 3 times all to end up with a stupid pickle fork that was wide enough, but the first one only took 4 hours of dickering around, and the other one took a whole 30 mins, hell $60 in parts and tools, better than $400 to have some shop do it!
