Please help with front driveshaft removal
Old Sep 5, 2014 | 10:32 AM
95dakoder's Avatar
95dakoder
Default Please help with front driveshaft removal
So i removed the 4 bolts at the front end of the driveshaft and got it loose, and now I can't get it to slide out from the transfer case. Is there a clip or something that I'm not seeing? It's a 5.2L 4x4
Old Sep 10, 2014 | 11:43 AM
RobertMc's Avatar
RobertMc
On my 1990, you unbolt the u-joint at the yoke on both ends of the front drive shaft.
Check for a factory service manual in the FAQ section. I believe there is a one for 1995s posted there.
(on my 90 the REAR shaft simply slides into the case on splines, and bolts to the yoke at the rear)
