Brake lights and flashers not working
Old Sep 9, 2014 | 10:35 AM
smellysell's Avatar
smellysell
Default Brake lights and flashers not working
My driver side rear light assembly got smashed, assembly was destroyed and the backup light socket was unusable too. Initially just replaced the assembly and everything worked fine (other than the one backup light obviously). Recently everything stopped working, other than the driver side brake light would work, until you put the blinker on, at which point it would blink but no brake light. Figured it was due to the backup light not being there, so initially tried connecting to the two wires to the backup light (dumb!) thinking that it might be a temporary fix and complete the loop until the new socket got here. It blew the fuse obviously, and after replacing the socket and putting a new fuse in, here is what I have.
  • Headlights and front hazards work
  • Front turn signals just light up solid when turned on
  • Tail lights and backup lights work
  • No rear turn signal, hazard, or brake lights
Please help!
Old Sep 9, 2014 | 10:45 AM
OMGnanerpus's Avatar
OMGnanerpus
Have you checked the relays? They shouldn't be too expensive. Just buy one and see if it fixes it. If not, you'll have a spare directional/hazard relay after you fix the issue.
That may fix the turn signals staying solid. But it sounds like wires got mixed up somehow to me.
Old Sep 9, 2014 | 10:56 AM
smellysell's Avatar
smellysell
Thanks, I'll try the relays.
Only wires I did anything with were the two going to the backup light, which was purple to purple, and black to black, so I don't think it was that.
Old Sep 10, 2014 | 12:06 PM
smellysell's Avatar
smellysell
Bad relay, and a bad connection between the sockets and bulbs on both sides.
Thanks for the help!
