1996 dakota wiring problem
Old Sep 9, 2014 | 12:28 PM
Jud980's Avatar
Jud980
Default 1996 dakota wiring problem
Hello I have a 96 dakota. I have a question about a wiring problem I have. The problem is that my abs and brake light on the dash are on. With them being on I've discovered that my turn signals radio and power lock button don't work. Does anyone have a clue how to fix this or what would cause it? Thank you justin.
Old Jan 9, 2015 | 09:05 AM
sbatiste92's Avatar
sbatiste92
Check both front ABS sensors and the rears as well. make sure they're all plugged in and not damaged. make sure that the switch for your E Brake isn't stuck. other than that, im not sure. also check your fuse for your ABS
