94 3.9 interchange to 2000 3.9
Old Oct 24, 2014 | 10:51 PM
dogrunner's Avatar
dogrunner
Default 94 3.9 interchange to 2000 3.9
hi. I picked up a 94 Dakota with a 3.9 water pump went out guy didn't catch it wipe out three cylinders. I found a 3.9 out of a 2000 Dakota with 73000 miles on it.is the long block the same. if I swap intake and the injectors will it work. thanks
Old Oct 24, 2014 | 11:24 PM
tbugden's Avatar
tbugden
RockAuto gives the same part numbers for both 1994 and 2000 long blocks so I think you're in the clear. Might want to double check with someone else to be sure though.
