Light around switch
Old Oct 31, 2014 | 04:21 PM
walt75's Avatar
walt75
Default Light around switch
Hi guys
My light around the ignition switch is burned out. Does any one of you guys know where I can buy one of the light bulbs?
Thank you
Old Oct 31, 2014 | 04:49 PM
What year? Google would be a good place to start.
Old Nov 1, 2014 | 01:20 PM
DaKotaK's Avatar
DaKotaK
I'm not sure if you can change just the lighted ring itself. It might be possible, but I have never tried and I would imagine that disassembly would be the same regardless.
However, the piece you are talking about comes with a new ignition switch usually and depending on the year is usually pretty cheap. The one for my 92 was $30 or so and just re-used the factory ignition cylinder. Here's a link to the part... http://www.autozone.com/starting-and...fi/966601_0_0/
Old Nov 1, 2014 | 01:31 PM
walt75's Avatar
walt75
Hi
I have a 1994 dakota sport
Old Nov 2, 2014 | 11:47 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm sure it is replaceable, if not it is replaceable with a similar size and solder it in. I know it is a very thin bulb, in my Ford I replaced an instrument panel bulb in similar size. Autozone had it.
