92 dakota RWAL
Old Nov 25, 2014 | 10:01 PM
Thomas_kota's Avatar
Thomas_kota
Default 92 dakota RWAL
So I think my rear wheel anti lock valve might be leaking a little bit past the dump valve. At first I thought my master was bad, so I replaced it. Bled the brakes (also had to replace lines and wheel cylinders because of rust). And that improved things alot but if Im sitting at a stop light my pedal starts out firm, then after about 10 seconds it will slowly start to sink. I haven had a chance to plug off and double check master, but it is a new/rebuilt one. Also couldnt get the bleeder to move on the abs valve at the rear mounted on the frame. Anyone got any experience with these? Next chance I get Im going to try to get that bleeder to move and re bleed all the brakes in the correct order and see where that gets me. Also I am not loosing any fluid at all.
also heres a picture of it for ****s
Old Dec 12, 2014 | 12:25 AM
Thomas_kota
Ok well about a week ago I bled the brakes more, and after letting penetrating oil sit on the bleeder for a week before, got the bleeder on the anti lock valve assembly to work. Bleeding it did not seem to help, but a couple days later the problem has gone away for now. So who knows.
Old Dec 12, 2014 | 08:16 AM
tbugden's Avatar
tbugden
I love it when problems "fix" themselves. People say cars don't fix themselves, but just give them a chance...every once in a while some magic happens.
Old Dec 13, 2014 | 12:17 AM
Thomas_kota
Haha IDK why but it came back today. Ill have to get one from a wrecker or some thing.
Old Dec 13, 2014 | 03:25 PM
wjohn's Avatar
wjohn
Just to cover the bases - I assume you bench bled the master cylinder, right? My pedal was sinking at stoplights (pretty randomly) and it was the master cylinder. If that didn't work I was going to move on to the RWAL valve.
Old Dec 13, 2014 | 05:50 PM
tbugden's Avatar
tbugden
Oh yeah good point on the bench bleeding the master. Sometimes it is nigh impossible to bleed a master cylinder on the car. Bench bleeding it is definitely the only way to go.
Old Dec 13, 2014 | 06:35 PM
wjohn's Avatar
wjohn
I think you can get away without bench bleeding on some vehicles, but based on the amount of time it took to bleed mine I think it's definitely necessary with the Dakotas. I bought a remanufactured master cylinder and probably spent about 15 minutes getting brake fluid worked all the way through it. That doesn't sound like very long but it's really tedious.
Old Dec 14, 2014 | 12:05 AM
Thomas_kota
Well I never did bench bleed. Next time I have spare time Ill give that a shot.
Old Dec 14, 2014 | 11:35 PM
tbugden's Avatar
tbugden
You mention replacing brake stuff because of rust, but from the pictures you posted in the other thread, your frame looks great!! I don't doubt the lines were rusted, but damn...that frame is clean.
Old May 2, 2015 | 03:38 PM
Thomas_kota
I fixed this issue a long time ago, but forgot to update thread.
The problem ended up being a defective master cylinder. I replaced the rebuilt one with a brand new one.
