CB Radio installation - 1996
Old Dec 4, 2014 | 10:00 PM
wirlebennoch's Avatar
wirlebennoch
Default CB Radio installation - 1996
I have a 1996 Dakota, and I am looking to install a CB inside. I will place it in a specially designed hump console, but I am struggling with the power and antenna. How can I hardwire it?
Also, I plan to use a magnetic antenna placed upon the roof, but how can I run the cable into the cab? Is there a grommet in the rear, or would it be safe (albeit ugly) to run it through the vent windows?
Old Dec 4, 2014 | 10:39 PM
RalphP's Avatar
RalphP
There isn't a grommet to the rear, but if you're very, VERY careful - and especially if you can remove the bed first! - you can add one, which is what I'm considering doing. That, or while redoing the headliner, drill the roof and mount a roof mount antenna for when I DO buy the CB and mount it.
As to how, if you have a specially designed hump console, can it cover and hide the wiring for the power to/from the dash area, where you can then run to the fuse box?
RwP
Old Dec 4, 2014 | 11:16 PM
wirlebennoch
I am also considering an antenna kit that will place a bracket to a bolt already under the lip of the hood. Any clue as to where a grommet is upfront? I want to avoid drilling in general.
The console is linked below. I would most likely run the power cable to the forward limit before lifting it up and running the cables behind the lower plastics going left to the fuse box. Now I just need to learn how to wire it from the fuse box, or could I power it by the passenger footwell light?
http://amzn.com/B00JKOONSM
Old Dec 5, 2014 | 02:04 PM
soar_dude's Avatar
soar_dude
Default CB install
I ran mine through the rear passenger window with no problems. I mounted my radio in place of ashtray with a couple zip ties and the side screw on the radio. Be careful though the antenna wire will rub the paint off the roof.
