5 speed swap
Old Jan 22, 2015 | 09:03 PM
JOE COX's Avatar
JOE COX
Default 5 speed swap
Will a 5 speed trans from a 92 dakota 3.9 work in 93 dakota 5.2 automatic and if so what bellhousing and clutch will i need?
Old Jan 25, 2015 | 04:51 PM
RalphP's Avatar
RalphP
It'll work, but for how long, I don't know.
The bell housing will fit as is (both are LA or Magnum motors), but the clutch will probably have to be upgraded. Again, the old one will WORK, but for how long, don't know.
You will need a 5.2 manual flywheel.
RwP
Old Jan 26, 2015 | 05:51 AM
93 ragtop's Avatar
93 ragtop
Ralph, when you say upgrade the clutch, exactly what do you mean? I think the stock is 10.4. If you go to a 11 will it bolt up? Also, I think the splines are 23 where as the newer trucks with a v8 are 10 spline.
Old Jan 28, 2015 | 07:26 AM
RalphP's Avatar
RalphP
There's more to the clutch than the size. I meant you may need a clutch with better frictions (possibly a different size), that would grab with higher torque. The one off the V6 may work perfectly fine for you, however, depending on how you drive the truck.
RwP
Old Jan 28, 2015 | 10:23 AM
93 ragtop's Avatar
93 ragtop
RwP
Ralph. Do you have any recommendations ie brand etc. I know rock auto and others show different ones. But I have yet to find anything listing high performance or even anything about material make up of the disc.
Old Jan 31, 2015 | 11:58 PM
RalphP's Avatar
RalphP
Brand of clutch? Dude, I'm totally shiftless - I just LOVE my automatics! (At least partly because of needing stuff the wife can drive, and right now she's got a bruised hip and cant' even run power brakes ... )
That said - I'd be seeing what's listed as standard for both motors with a standard transmission. If the same clutch for both, you should be good. If different ones, then I would bet it'll be due to the higher clamping / better frictions on the V8 clutch.
RwP
