Distributor 180 Degrees Off???
Old Feb 23, 2015 | 08:36 PM
Dakotr95's Avatar
Dakotr95
Yeah, I know. When I installed the timing chain, it was very loose. Supposedly, the previous owner had changed both the timing chain and gears. My suspicion is that probably the chain skipped a tooth or more. I guess I'll have to open up the timing cover to check whats going on. I'm going change the gears, timing chain and see if I can install a tensioner on there as well.
Old Feb 24, 2015 | 02:33 PM
Cooreman's Avatar
Cooreman
If you were out 180 it would back fire out the throttle body. Very notable sound
Old Feb 25, 2015 | 11:32 AM
Dakotr95's Avatar
Dakotr95
Yes, it does make a wired sound that comes from the intake when I open the throttle body. When you say "180 out", do you mean 180 out on the distributor or on the timing chain gears?
Old Feb 25, 2015 | 12:03 PM
Cooreman's Avatar
Cooreman
I was talking about distributor. I don't know if these motors are interference or not so I'm not to fluent on the actually timing chain them selves
