Dorman intake gasket opinions
Hey all,
How do you guys feel about Dorman products? I found a complete intake and plenum repair gasket kit with bolts and thermo at pepboys.
http://www.pepboys.com/product/details/495309/00604
I also have a 35% off code if I buy more that $100 so I'm thinking of getting several upgrades together
If you guys are interested the code is:
Secret35
This will roughly make it around 34 bucks, which is better than ebay. Plus I much rather buy from pepboys than ebay. Though, I will probably buy the aluminum plenum off ebay...
Let me know what you guys think.
Thanks!
Secret35
Thanks!
I've used quite a few dorman products with no issues but I will agree they're not grade A quality in everything they do. I've used everything from window motors to brake parts to a nylon fuel line kit for doing custom lines (which is an awesome kit IMO). I do notice that they're metal parts don't have the best rust proofing...for example parking brake connectors. They're sturdy enough but rusted quick. I sprayed them liberally with fluid film do they should be good for a while. Don't remember if I've ever used gaskets. As Ralph said there are better options but I wouldn't hesitate to use them if that's what was available.
If money is a big deal then it will probably do just fine. I used this kit http://www.hughesengines.com/Index/p...2&partid=26194
Because it fixes the plenum problem permanently. I had the intake tanked and the TB too along with replacing all the sensors on the TB and the 2 coolant and the intake air temp sensor. My gas mileage went form 9 mpg to about 18mpg. I got the new intake bolts too.
I had a ticking noise on mine so I did the timing chain and added the tensioner in TSB http://dodgeram.info/tsb/1997/09-07-97.htm at the same time. I only wish I knew the hydraulic lifters (also a probable source of the ticking) were right there I probably would have done them too because the ticking is still with me. I don't want to take the intake off again just now.
