idle flucuates
Old Apr 6, 2015 | 08:45 PM
Jim1993Dakota's Avatar
Jim1993Dakota
Angry idle flucuates
1993 Dodge Dakota 5.2L idle fluctuates up and down on its own, help me.
Old Apr 6, 2015 | 10:46 PM
Have you checked/replaced anything yet? Start with the IAC.
Old Apr 7, 2015 | 12:03 AM
RalphP's Avatar
RalphP
As JKeaton says, IAC first, then general maintenance (plugs? wires? distributor cap and rotor?), then also check ALL vacuum lines. ALL of them.
RwP
Old Apr 8, 2015 | 11:29 AM
Jim1993Dakota
1993 Dodge Dakota Truck, Le, 5.2L Magnum, Idle Speed Fluctuates, ruffidle, smoke out of the tail pipe, I have changed: EGR, O2, IAC, TPS, PCV, NewBattery, Re-built the engine, changed ( rings, rod bushings, oil pump, machinedboth heads, Plenum gasket, intake gaskets, cleaned throttle body, changed plugsand wires. I don’t know what to do now..
Old Apr 8, 2015 | 11:37 AM
Jim1993Dakota
thans for quick reply
