Wiper bushings
Old 01-23-2016 | 11:00 AM
KevinSandidge's Avatar
KevinSandidge
those arms have been shuffled around in there so i'm hoping the orientation is the same as on my 94. thanks guys.....i gotta clutch problem to deal with first i just found out :/
Old 01-23-2016 | 11:25 AM
RalphP's Avatar
RalphP
87-96 use the same wiper arms and orientation, so that should help some.
RwP
Old 01-28-2016 | 10:15 PM
keilkravec's Avatar
keilkravec
Rockauto has all the orginal bushings for the arms, far driver-side is a double valley-type bushing, has 2 slots for where the arms meet. center and passenger are 1-valley. I was able to pop mine in and out without pulling the linkage apart. just use some vice grips and angle it right and you can do it through the cowl.
Old 01-30-2016 | 06:44 PM
angrysmileyface's Avatar
angrysmileyface
I would up not replacing the donut and decided to go wit the multi kit from the parts stores and filled them with chassis grease. To pop them on without removing all the linkage I used a hose clamp tool. Ie the kind that removes oem style clamps not worm gear clamps
Quick Reply: Wiper bushings
