Greetings! And a transmission question...
Old Jun 16, 2015 | 01:38 PM
VMX12Rider's Avatar
VMX12Rider
Default Greetings! And a transmission question...
Howdy! New to the forum! And so it begins.... Just bought a 1996 Dakota SLT, Extended cab, 2wd, 5.2 automatic and I'm really rather keen on it. I've been sorting out the previous repair attempts and other signs of neglect. I'll save the laundry list for later. My question is transmission related..
When I went to look at the truck, the owner said the transmission had been replaced with a 77K mile unit, the flex plate, the torque converter have also been changed out. They look brand new. The drive shaft has also been replaced. I didn't experience it during the test drive, and truth be told, I don't experience it 99% of the time simply because how I drive is that the transmission won't come out of second until (Almost exactly) 38 miles an hour (Per the speedometer).
I don't experience it as most streets around here are 40 mph. So as soon as I reach the magic number it shifts normally, Once it goes into third, I can ease off the gas and it'll fall into fourth normally. I can let the speed drop down into the 30's and it'll behave just fine. But for whatever reason if I don't get it up and out of second it'll want to stay there. If I don't get it out of second and let off the gas, it'll actually engine brake and the exhaust will burble (Which I guess sounds cool? I'd rather 3rd gear though). If I hammer it it'll kick down and behave normally. It's really only an issue on slow side streets, parking lots, traffic. I've tried taking the gear select when it was hanging in second and shift it manually into 3rd and it didn't respond. I gave it some gas and pushed it to 40 and it shifted properly.
Transmission's aren't my strong suit. I've done clutches in standards and dropped them before, I've changed out filters and gaskets, adjusted linkages and whatnot, so I figured I'd better ask before I start monkeying in there. I've checked the forum and when everyone else said 'stuck in second gear' they mean like, permanently. Which isn't my problem. Also Identifix doesn't seem to have any hits. So, Ideas? Thanks in advance.
Old Jun 17, 2015 | 07:40 PM
onemore94dak's Avatar
onemore94dak
Here is a possibility http://www.justanswer.com/dodge/1otj...-throttle.html Or this one http://www.bionicdodge.com/Download/...Adjustment.pdf If that does not help I'm guessing at this one maybe the Overdrive solenoid. I had shifting problems in my 94 V6 Magnum and got mine rebuilt and then got more improvement than the rebuild when I changed the Crank Position Sensor. :/ Welcome and Good Luck
Old Jun 19, 2015 | 09:35 PM
VMX12Rider's Avatar
VMX12Rider
Default Update!
It was TV cable related... I was under the truck. Monkeying with the o2 sensor. After a few frustrated minutes I decided to creeper over to the transmission and have some eyeball with it. The TV cable wasn't even attached to the transmission, and the spring was just dangling. After sorting that out and some trial and error with the adjustment at the throttlebody she's shifting like a dream... So the good news... the problem has been sorted... the bad news... I'm starting to question who's been working on this truck...
