1993 Dakota Club Cab with a 3.9L V6 Standard. Broke my rollover valve just barely pulling on the hose. Definitely a dry-rot issue and needs to be replaced.
pic taken right after removing the bed. Washed before disassembly to prevent dirt from getting in. Nasty!
I took the whole bed off to work on this. Much easier access. The replacement fuel pump was easy enough to find. Finally went with an aftermarket Martin brand 4762996 or 4762405 for just a little over $50 on Ebay.
Other manufacturers and part #'s:
Precision A30048
Delphi - DFG0206
Spectra - D115M
Carquest - E7050M (didn't get good reviews)
Delphi - FG0206
Denso - 953-3069
Bosch - 67614
Delphi Series 7000 - E3001149016DEL
AAP Aftermarket - FMD010392
I'm sure there are others but these are the ones I looked at.
But the Rollover Valve? Heh, Mopar Part #04279941 is a wash.....it's been discontinued and no aftermarket part available. Dorman makes a part 911-001 or 911-061 but I'm finding those may not work either. No work-around offered by the Dodge Dealership or local Auto Parts Places....that's O'Reilly's, Autozone, or Advanced Auto. Finally found a piece that may work and waiting for it now.
Now these work-around replacement Rollover valves don't look anything like the OEM originals but they do the same job with a change in the way they're constructed. They're supposed to relieve excess fuel tank pressure and prevent gas from leaking out of the tank if you flip your vehicle. If you're going to do your own online search, here's some of the verbiage for the part:
Fuel Tank Vent Valve,
Fuel Tank Rollover Valve,
Pressure Sensor Valve,
Pressure Relief Valve,
Pressure Relief/Rollover Valve,
Rollover Valve,
Fuel Tank Vent Rollover Valve, and
Vapor Valve.
Funny hunh? Everybody has a different name for the same part. I think it's stupid and makes searching for this a whole lot harder; That's like calling an Alternator a Magnetic Induction Voltage Stepdown Charging Unit ! ! ! Hah, I just made that up! Hope this painstaking research helps some of you. Let me know. I'll post my results and pics after the install. Here's a pic of the assembly. Diagram of Fuel Pump Components for a 1993 Dodge Dakota Club Cab Sport 3.9L V6 Standard. Others may vary a bit.
Precision A30048
Delphi - DFG0206
Spectra - D115M
Delphi - FG0206
Denso - 953-3069
Bosch - 67614
Rollover Valve,
Vapor Valve.
I’m looking for this part or a fix without having to purchase the entire tank and assembly please. It’s a 3 way valve .. very brittle. Broke upon removing. Please advise Thank you 🙏🏻 Looking for replacement part Broke the nipple from the attachment Trying not to purchase entire fuel tank Please advise and or hep. Thank you 🙏🏻 Close up
Did you ever figure out a repair without replacing whole tank
My 94 Dak, 5.2lMag, Roll over/whatever it is valve. Mine is in the fuel pump module. Don't know how many ports. I found a single port valve with a grommet on that Amazing Place. When I remove the bed to replace the fuel module, I'll try that valve. Well, maybe I should see if it will fit now, before I remove the bed.
Let us know what's happening with yours?
