Oil pressure
Oil pressure
I was at a redlight in idle and all of a sudden my oil light started to flicker and the gauge dropped? The needle was jumping everywhere. The truck sounded fine. It did it again a couple days later. It doesn't happen everytime at a low rpm/Idle but I am concerned.
What do you think is going on there? Sending unit? Bearings? pump??
Going to check the oil pressure today.
It does not say what motor. I have the 94 3.9 magnum. I had a high pressure issue and since i knew the oil was good I went straight to replacing the sender unit. It's less than $20. You may need a special socket to remove/install it I did, also less than $20. The sensor is located in the back of the intake near the EGR under all those vac hoses and wires.
