Davis unified hei ignition ?
Old Oct 6, 2015 | 01:42 PM
dakotakid17's Avatar
dakotakid17
Default Davis unified hei ignition ?
Hey guys I was wondering if anyone has bought or used the Davis unified hei cap and rotor would be nice to have a little bit more of a clean look under the hood and to have a better cap and rotor the part number is 35200RD plz let me know thx
Old Oct 6, 2015 | 04:51 PM
93 ragtop's Avatar
93 ragtop
I don't believe you can use that without the distributor. Its basically a GM HEI design. Also, I don't believe you could use it with the factory fuel injection. I think you would need to be running a carb.
FWIW I thought about using one on mine. I plan to run a 318-360 magnum with a carb intake. But I think I will stick with a basic electronic ignition from Mopar. I cant justify the difference in cost.
Here is a link that will take you to the actual distributor. http://performancedistributors.com/p...-distributors/
