Plenum gasket help needed fast
Old Dec 29, 2015 | 02:06 PM
blizzblang's Avatar
blizzblang
Default Plenum gasket help needed fast
So right now I'm mid-repair in the plenum gasket replacement.
I got all the bolts off and the only thing thats holding it on is what I think to be the gas line.
Metal clips
Took off the metal clips
Manifold as is. All 12 bolts removed
The gas line getting in the way. Or whatever it is
What should I do from here? The cable has no give to it, very stiff.
Old Dec 29, 2015 | 04:25 PM
RalphP's Avatar
RalphP
It's the fuel rail.
It will disconnect from the gas line at that junction right above the bolt furthest behind the injector at the right in that last picture - where that connection is.
You probably need a tool like this to get it loose: http://www.autozone.com/test-scan-an...ol/429543_0_0/
They're cheap enough at AutoZone / Advance / Harbor Freight / et al.
RwP
Old Dec 29, 2015 | 04:55 PM
onemore94dak's Avatar
onemore94dak
That cap which has a Schraeder valve under it press it to release the gas pressure.
Old Dec 29, 2015 | 06:01 PM
blizzblang's Avatar
blizzblang
Is there anyway to do it without the tool?
Old Dec 29, 2015 | 07:53 PM
RalphP's Avatar
RalphP
I'm sure there is, but it's so easy with the tool.
And I've never HEARD of a way shy of "Cut the rubber hose and rebuild it", which will be worse.
RwP
Old Dec 30, 2015 | 09:41 AM
onemore94dak
Didja look at this page? http://www.****************.com/smf/...p?topic=9504.0 As I recall I simply tied it to the master cyldiner or something at that corner of the engine bay. The page is of a 99 V8 plenum job and mine is a 94 V6 but yours looks like you could do the same. If that page link doesn't work it is the page that links from the Hughes Engines V6 plenum repair kit page. They recommend it as the instructions and if you bought their kit they will give youhelp via the phone if they can.http://www.hughesengines.com/Index/p...=&partid=26194 RUN A VACUUM THROUGH THE TOP BETWEEN THE VALVE COVERS AND THE INTAKE BEFORE YOU PULL IT OFF.
Old Jan 1, 2016 | 08:44 PM
blizzblang's Avatar
blizzblang
Ended up just pulling them off with a screw driver and some leverage, got gas everywhere but it did the job.
