Broke something, need help
Old Dec 30, 2015 | 04:55 PM
blizzblang's Avatar
blizzblang
Default Broke something, need help
Where it screws into.
What's broken.
Top picture was taken next to the distributor, at the back of the engine.
When I was loosening the pipe ( top picture ) that leads to the exhaust, I snapped the bottom picture in half. What is it? I can't put the manifold back on until i replace it. its in a tough spot.
Old Dec 30, 2015 | 05:40 PM
onemore94dak's Avatar
onemore94dak
That is your Oil Pressure sending unit. Its like $20 and easy to replace while it is apart. If you put the intake back on first which I think you have to you will need a special socket for it. I think that cost me less than $20 too. You will have to get that EGR pipe started before fixing the intake back in place. I suggest that you do that before even trying to start any of the intake bolts.
