93 Dakota V6 Defroster Only
I've tried to read several posts on the issue. Got into the truck noticed I only had defrost which I guess is default mode. Found a bad vacuum hose and repaired. Still the same problem. Could not find any other leaks. Curious about the vacuum ports/solenoid in the attached picture. Don't know what it controls. Any help or knowledge of the problem and identification would be appreciated. Thanks!
I couldn't find it maybe Ralph knows but there is a TSB for a vacuum issue on some Daks where you have to install a special vacuum diverter on the engine side of the firewall as a design fault allows some vacuum pressure diversion which causes the defroster vent only problem. Or it could just be old leaky rubber o rings and vacuum lines under the dash
