Tourque Converter problems!
Old Mar 5, 2016 | 09:40 AM
Grease_Junkie's Avatar
Grease_Junkie
Default Tourque Converter problems!
How's everyone? I got a 92 5.2 2wd auto and I can't tell if my tourque converter or Rearend is going out. When I go from park or neutral to Reverse or 1 2 or D it wants to die but if I hurry and throw it in park or neutral it idles back up and is fine. When I do get in to go in gear it will move but as soon as I give it gas it locks up and dies. I was able to drive it last week tranny shifts great but when I would take of before it shifted to 1st it would jerk real bad. I always owned 5/6spds don't like autos but got this truck for a steal any help would be appreciated. Thank you
Old Mar 5, 2016 | 10:12 AM
Easiest thing to do first is remove the rest diff cover and inspect the gears.
Old Mar 7, 2016 | 11:53 AM
Grease_Junkie
Ok I'll be doing that tonight I've been working out of town but I've been seeing and reading it sounds more like a tourque converter cause I hear no noise I could freely move the wheels while i had it jacked up in neutral.
Old Mar 14, 2016 | 09:19 AM
Grease_Junkie
Ok I put a new Rearend in 3.55 gears locker didn't fix problems. The other rearend was bad but I believe it's the transmission so I'm gonna start looking for a Nv3500 or get this one built.
Old Mar 24, 2016 | 08:00 AM
Grease_Junkie
Ok I'm at the end of my fuse, I am assuming it's either the tcc or tourque converter itself but just the other week I was driving if and it shifts great and doesn't slip at all goes into overdrive no problem. I'm going to change tcc tomorrow if I'm off but before I do has anyone had this problem or maybe some advice cause finding a nv3500 isn't gonna happen around here. Any help would be appreciated just don't think it's my tranny gotta be tcc or bad ground.
Old Mar 24, 2016 | 08:49 AM
Moparite's Avatar
Moparite
Any codes? That's the first place to start.
http://www.allpar.com/fix/80s-codes.html
Old Mar 24, 2016 | 09:07 AM
Grease_Junkie
I have no codes no cel on and runs great I think I might unplug and see if it will go in gear I read on here few min ago had sane prob unplugged an worked just no OD so that's all I can think of but thank you
Old Mar 24, 2016 | 12:40 PM
RalphP's Avatar
RalphP
Did you run codes, or are you just going on "CEL not lit"?
RwP
Old Mar 24, 2016 | 03:09 PM
Grease_Junkie
Yes I was I until I got a chance to click the link. I'm at work. Thank you btw. Next ? Is seeing how I've not seen my cel light come on should I reset PCM or just check for codes first? I read here awhile ago you unplug battery and turn key on for 15-20sec this correct?
Old Mar 24, 2016 | 05:35 PM
RalphP's Avatar
RalphP
Check for codes first.
It'll flush several out while you're checking.
RwP
