88 v6 trouble starting in warm weather
I have an issue with my 1988 Dakota 5 speed having a hard time starting when the weather gets above 65°. From a coldstart it is fine but once it warms up sometimes you have to crank it for 15 to 20 seconds before it starts. Sometimes it won't start at all. It seems like it is flooding. But I am not sure how to remedy this issue. There are no codes that I can see. I did the Key turn code reading method and got A system normal code. The plugs And rotor and wires are all new also.I am wondering if there is something wrong with the injectors. Any help would be greatly appreciated. Thank you!
I'd be checking the fuel pressure - if it's over 14.5psi by much, it won't fire; also, if the regulator has a leak, it'll leak down and you won't fire.
Two more things to try:
1) Turn it on, wait four seconds, turn it off, on, four seconds, off, on, four seconds, off, try to start. This reprimes in case it's a lost prime due to leakage.
2) Since there's no Schrader valve on our fuel systems (I also own a 1988), you can't just clamp a fuel pressure gauge on it; but if you could T and check the pressure, that'd be a great idea.
3) If it IS the injectors, you can buy those for not really that much ($35 each at Motor Man, http://www.fuelinjector.citymaker.co...17/4589594.htm ) and swap them.
4) Also, before swapping injectors, NOID those things (attach a NOID light and get it to "fail" so you can verify that the injectors are being fired).
I'll also ask, how long since the last time you changed the fuel filter? There's one attached to the frame, about the middle of the driver's door, to the inside; my 1988 has a Wix 33321 on it right now. Check that out also; it may be plugging when warm.
RwP
RwP
Sorry it's been a while since I've replied, I have now replaced both injectors the fuel filter the oxygen sensor the fuel pressure regulator are all plugs and wires cap and rotor and I'm still having the problem. There are still no codes. It seems as if it is trying to choke or as you said spray more fuel in the throttlebody when it is trying to start. What I mean is it seems to be flooded and that's why it won't start. What would cause the ecu to think that it is cold?
