Gas mileage dropoff
Old Jun 17, 2016 | 06:21 PM
onemore94dak's Avatar
onemore94dak
Is it possible my new larger bore exhaust from the Y back is causing me to consume more gas?
I tightened up the U clamps today after a long drive got it hot. It was surprising how much the nuts drew up since I made it as tight as I could when I installed it.
Old Jun 22, 2016 | 11:20 PM
onemore94dak
I changed out the plugs. I had replaced two with different brands over the last year. I managed to break one of the new ones so I cleaned up the best used one of the manufacturer recommended brand (Champion) and installed it where I can replace it easy. I don't have any MPG changes to report as I haven't driven much yet but I have noticed a gas smell when I start it?????? It "feels" like gas is pouring into the motor and not giving the power it should as well. The feeling is that its not quite responding as soon as I change the angle of the peddle and it seems like there should be more power than I am getting. It jumps and goes when I punch it, way better than it ever did before I fixed the exhaust.
