91 318 LA to 99 318 mag swap questions
Old Jun 12, 2016 | 09:15 PM
RalphP's Avatar
RalphP
The early Magnums were single line feed.
You won't have to change the intakes, they're the same AFAIK.
Regulator was on the fuel tank for a Magnum for the 1st Gen Dakotas.
RwP
Old Jun 12, 2016 | 11:07 PM
jake122288's Avatar
jake122288
RwP
Guess I'm going to just have to go search the junkyard this week.
I was reading somewhere that the intakes had egr on the early dakota magnum engines and had a return line still.
Ill post back after I get to the junkyard and let you know what I find.
I'm gonna take a look at the dash wiring and bulkheads and everything too hopefully a visual will help me figure out exactly what I want to do. Thanks for the input so far.
Old Jun 13, 2016 | 12:59 AM
RalphP's Avatar
RalphP
I'd also spring for the 1999 RAM factory service manual; also the service manual for your truck; and I'd highly consider the owner's manual for whatever year Magnum Dakota you pull the wiring harness out of.
RwP
