fuel pump run with key on or engine cranking/running?
Old Jun 22, 2016 | 06:26 AM
bfowler92's Avatar
bfowler92
Originally Posted by RalphP
Even with the distributor hooked up, you won't get but a couple of seconds at best; unless you're generating ALL the clock signals (cam, crank, etc.)
RwP
That's all I'm looking for, just so it comes on for a couple seconds to prime. Thanks for the help
Old Jun 22, 2016 | 07:48 AM
RalphP's Avatar
RalphP
Why not just jump the ASD then?
That should prime it up.
Or, when you DO get the motor in (since it won't prime without the fuel injection connected!), check it then.
RwP
Old Jun 22, 2016 | 07:49 AM
bfowler92's Avatar
bfowler92
RwP
I just want to verify its working as it should is all.
Old Jun 23, 2016 | 01:24 AM
Friar Tuck's Avatar
Friar Tuck
Jump 12 volts from pin 30 to pin 87 of the ASD relay socket with the relay removed.
That is called the ASD Bypass.
Pin 30 is the 12 volt input to the relay.
Normally, when the relay is energized, pin 87 is then connected to pin 30.
You're just making the connection without the relay being installed
Old Jun 26, 2016 | 08:14 AM
bfowler92's Avatar
bfowler92
Asd bypass was good. I will be getting an engine for it wednesday or thursday and will install next weekend. I will update on how it goes. Thanks again for the help.
