MT 2500 Question
Old Jun 16, 2016 | 01:29 PM
onemore94dak's Avatar
onemore94dak
Default MT 2500 Question
Does anyone have a MT 2500 they have used for Gen 1 ABS RWAL?
I had a brake warning light and ABS light come on. The issue is now fixed.
When the problem first occurred the Chry-1 plug gave me a message that said it could not communicate with the RWAL system. I discovered there is also a Chry-2 connector that will plug in under the dash and ordered it. It happened to show up as I was fixing the brakes. Its supposed to be for the ABS. I have tried it and I get the same message I got using the other plug. That message is;
"No comm available. For troubleshooter, Use power pac, or use Multi-1 with ground extension & either power cable. Press Y to continue. "
There is no power source for the Chry-2 plug and the book says that it works without supplied power. I only have the power line that plugs into the lighter. I have no idea how I might use a power pac or what the Multi-1 is. I think I understand the ground idea and I suppose I could splice one in but the book does not show any cable with a ground for this unit.
The Primary cartridge is the MT25001099 & the Troubleshooter cartridge I have in is the MT25002900
I have another Primary MT25001000 & Troubleshooter MT25002998
Old Jun 21, 2016 | 11:59 AM
onemore94dak
Nobody ???
Old Jun 21, 2016 | 04:04 PM
bfowler92's Avatar
bfowler92
Heres a bump for ya, I have a mt2500 but dont use it much . All my vehicles are obd1 or to new for the software.
Old Jun 21, 2016 | 05:47 PM
onemore94dak
Thanks. It does work on OBDI if you have the cartridges.
Old Jun 21, 2016 | 08:14 PM
bfowler92's Avatar
bfowler92
yea I know I just don't have them. goodluck
