1990 2x4 auto 3.9
Old Oct 23, 2016 | 11:25 PM
mark38090's Avatar
mark38090
Default 1990 2x4 auto 3.9
Can the tv cable/ linkage be removed without causing issues? If mine gets moved even slightly it causes the transmission to stick in 1st gear for a while. No rhyme or reason when it decodes to shift again, it just starts working on its own.
Old Oct 24, 2016 | 02:12 AM
dakota1996's Avatar
dakota1996
Are you referring to removing the cable running to the gear selector on your transmission from your steering column?
Old Oct 24, 2016 | 09:07 AM
RalphP's Avatar
RalphP
On a 1990, there is no cable; it's a hard linkage.
Also, on the hydraulic transmissions (dakota1996's is electronically controlled), there's a Throttle Value (TV) linkage that lets the transmission know that the throttle is being depressed so it can do a proper down shift.
To answer Mark38090's question - Not if you want the transmission to last. At least, not without going to a full manual valve body inside the transmission and hand shifting it.
RwP
Old Oct 24, 2016 | 12:37 PM
dakota1996's Avatar
dakota1996
RwP
Ohh alright thanks for clearing that up I hadn't messed with the autos in these years really.
Old Oct 24, 2016 | 06:06 PM
mark38090's Avatar
mark38090
My problem is whatever it connects to on tranny is sticking. So if it kicks down for any reason it won't shift out of 1st gear for a while. Eventually it just starts shifting again. What should i lube.
Old Oct 24, 2016 | 06:10 PM
dakota1996's Avatar
dakota1996
RwP
I run a manual so I don't mess with the auto's as well.
