1993 Dakota
Old Nov 5, 2016 | 11:09 AM
  #21
Butters's Avatar
Butters
Originally Posted by ragged89
Not too bad, in fact its probably better rust-wise than mine. Rear half of the frame usually gets the worst of the rust, other than the front where the shocks attach. I can't see a spring crack either, does the truck sag on one side at all? That would be typical of a broken spring.
Sorry about diverting your post by engaging in the engine debate. It was way more than most anyone would care about.
No worries. To be honest I would probably rather the V8 and 4wd but all I can find around me have close to 300k miles and cost more. Nice to see them up that high but it makes me a little uncomfortable. I could not tell if it was sagging to one side or not.
Old Nov 5, 2016 | 12:29 PM
  #22
tbugden's Avatar
tbugden
$400 heck ya hard to go wrong at that price.
Old Nov 5, 2016 | 01:14 PM
  #23
Butters's Avatar
Butters
Ok. i looked a little closer at the pictures and I think I found a crack.
Old Nov 5, 2016 | 01:42 PM
  #24
ragged89's Avatar
ragged89
I thought that was a pad, but maybe... That's an odd place to crack one, at the tip like that. If that's it I wouldn't be too concerned, at least not at the price you were given. Replacing a leaf spring isn't too bad of a job.
Old Nov 5, 2016 | 09:11 PM
  #25
MacDak's Avatar
MacDak
Heck, for $400, it's about got that much worth of scrap steel in it! Plus the tires look fair. Oh, hey, I love my '93 3.9 V6! That thing takes a beating and keep on going strong. And all highway trips I get 20-22 mpg. I'm good with that.
Old Nov 6, 2016 | 12:53 PM
  #26
Butters's Avatar
Butters
I found another 93 with V8 and 4wd but they say the transmission is weak. I assume this means it's on it way out. Is this common or is there a fairly inexpensive fix?
Old Nov 6, 2016 | 01:23 PM
  #27
RalphP's Avatar
RalphP
Most 1993 anythings are having transmission problems due to a combination of age, usage, and neglect. (Hey, sounds like ME there ... and my body!)
"fairly inexpensive" depends on what you define as inexpensive. Local shop wants $1600 to $2200 to rebuild my 3 speed Torqueflite on my 1988; yours will be the 4 speed (3 speed plus integral overdrive) and will be about the same.
RwP
Old Nov 6, 2016 | 01:59 PM
  #28
Butters's Avatar
Butters
This is the response I received from the current owner. Also, it is a 91 and not a 93.
It's shutters between first and second. Also slow shift when cold.
Old Nov 6, 2016 | 02:36 PM
  #29
RalphP's Avatar
RalphP
Two more years wear, so even more so what I commented on.
Have the fluid and filter changed (note: Do NOT do a quick flush!), paying careful attention to the sludge in the bottom (there will be SOME, but you want a very thin layer with no metallic glitter, or a very minimal amount. If it's 1/4" deep and glitters like a My Little Pony birthday party, it's toast.). While doing that, have the shop also adjust the bands. Be SURE to use ATF+4 in it; your symptoms may be a previous change with Dexron instead of ATF+4.
If that doesn't cure it, then it's time for a rebuild. OTOH, your symptoms MAY just be some slippage caused by the bands being out of adjustment, or slippage due to the improper fluid being used.
RwP
Old Nov 6, 2016 | 03:07 PM
  #30
Butters's Avatar
Butters
They said they put in some stop slip treatment but does lint know what brand but it didn't help.
