Fumes in cab
Old Dec 24, 2016 | 03:09 PM
onemore94dak's Avatar
onemore94dak
Default Fumes in cab
What could be the source of exhaust and gasoline fumes in the cab when the motor is running and the truck is still? It has a rear slider window but I don't think that is all of the problem if the exhaust is coming through there. I re-tightened the exhaust I installed a couple of times to be sure it wasn't leaking. I can't imagine how the fresh gas smell is getting in as I see no holes in the firewall.
Old Dec 24, 2016 | 03:13 PM
RalphP's Avatar
RalphP
Don't forget to check the hood/cowl weatherseal, also if there's a leak about where the drain is for the cowl you'll get fume induction back up that way (run some water into the cowl to see where it drains out at the bottom).
RwP
Old Dec 25, 2016 | 04:35 PM
onemore94dak
Hood seal looks good haven't been able to test the drainage yet.
Old Dec 25, 2016 | 08:59 PM
ocdropzone's Avatar
ocdropzone
rusted out floor boards?
Old Dec 25, 2016 | 09:23 PM
onemore94dak
I was lucky the body is rust free. Well there is superficial rust where paint has chipped but the first thing I did before buying was crawl under it and look it over and all was good.
